RCU Forums - View Single Post - post some pictures of your pattern plane!!
Old 11-02-2020 | 09:57 AM
  #1218
FLYERSG
Originally Posted by rcprecision
Mike,
Motor - C54-2Y L Acro 6.7.1 Competition
I measure amps static on the ground. I set the throttle as not to exceed 90amps at full throttle. This is the same process I've used to set up C50's 14XL Comp's and Plettenberg 30-10.
OK...thanks. I have a couple of C50 XL motors that I've used in various pattern ships over the years....great motors. I notice you're using the shorter L motor rather than the XL. Is the shorter L motor able to handle the power of 10S packs and 21 - 22" props without getting too hot?
Mike
