Originally Posted by
Dave Wilshere
1. What about when the wheel is on the outside of the leg?
2. Electron and other quality TL legs have almost no free play, the old tubular leg with a sliding pin/screw needed the wheel twisting to take up the free play, then the leg setting.
Dave
Mmmmmm, good point Dave, I supposed all the struts/wheel combos that I have installed in the last few years have had some kind of play and setting them up straight has worked, I have not had the opportunity to play with gear sets like the Electron ones and have not work with wheels on the outside of the struts, in that case then a bit toe in is preferable.
