Toe-in best practice and technique >
Old 11-05-2020 | 02:15 AM
Originally Posted by JackD
I think the net result of what you and I are recommending is the same. Toe out to minimize bite and avoid zigzag/wingdance, specially on cross wind.
Regarding toe in/toe out on race cars, I kinda trust JP Montoya on his explanation
Please read the article if you want. Last paragraph states:
"On the rear, there will always be Toe In or 0deg of Toe. You will never use Toe Out in the rear. "
regards
Nuno
Old 11-05-2020 | 04:22 AM
CraigG's Avatar
My Feedback: (40)
Originally Posted by Dave Wilshere
I have covered it in RCJi more than once 😉
Removable wings like this, one piece wing it’s best to put it on the fuselage and reference off each side. I use 2’ long rods and set around 3/8” wider at the rear.
If you use this method (which I do), you have to be sure the wing root is actually parallel with the plane's centerline. Many are, but not all. If not, you can use a string taped between the nose and tail of the fuselage and use that as a reference.
Old 11-05-2020 | 04:54 AM
skunkwurk's Avatar
My Feedback: (18)
will do - thank you for the heads up and string suggestion.
Old 11-05-2020 | 07:00 AM
AEROSHELDON's Avatar
My Feedback: (99)
I just use my straightedge like mentioned above and always but the wings on.... just easier for me to see it all.
Old 11-05-2020 | 12:18 PM
skunkwurk's Avatar
My Feedback: (18)
thanks!
