RCU Forums - View Single Post - 1/10th scale Hydro Build
Old 11-05-2020 | 02:34 AM
  #31
Hydro Junkie's Avatar
Hydro Junkie
These pictures might help a bit:
You can see the cross framing in between the sponsons at the front of the boat that the deck and bottom are glued to. You can also see, in many of the pictures, how I used 3mm glue blocks to re-enforce gluing locations. I don't know what your plans show but another option would be to rough shape a bulnose(nose block) and glue it to the hull in the appropriate location, gluing the bottom, decking and side panels to it
