Originally Posted by
FenderBean
Go into the ECU under the info section were you prime, check valves and make select ignitor, maybe switching it on and off will fix it. That should be disabled but if you have an older motor it maybe still enabled, that being said it should cut off when powered down.
Good Idea. Ive just tried it and its stuck on. I'll send it back to Spain. Thanks for your thoughts.
