RCU Forums - View Single Post - ground loops
Thread: ground loops
Old 11-09-2020 | 12:13 PM
  #36
jester_s1
Moderator
That last description sounds like a gear setup issue. I mentioned above a plane I had once where the gear and rudder had different neutral positions. That'll have you wagging your tail on the runway for sure. It also sounds like you might have some toe out if it's just plain squirrely like you describe. Another possibility is simply a too narrow stance, which exacerbates any other problems.
