CG
The cg is 5" from leading edge of wing. Cord is 18". The CG is marked on the fuselage but it did not show up in the image.
The throttle curve softens the low end more than the middle. The servo moves 90*.
Throttle closed to fully open is 90*.
2 1/2 " axel forward of leading edge of wing does not seem good. The next time I go to the field a more aggressive throttle curve and another landing gear will be used.
Jerry
