Install pitot tube
I will be using a Digitech CTU with an airspeed sensor. Foam had to be removed from the radom to install the pitot tube.
Careful at the nose since removing too much foam will cut through the surface. Just enough clearance for the air tubes to the module is all that is needed.
Done
Doesn't look bad.
