Just for the record, before anyone notices, the retracts are each on the wrong side. The wheels go towards the outside! UPDATE: I fixed it. There are two more tasks before actually gluing these formers into the fuse. First, I need to make the actual flight gear mounting beams. The ones in the picture are still the PLA 3D printed ones. The 5/8" square stock was ordered, and should arrive today. The second task is to machine a tubular spar that will span all the way from the left set of formers to the right set. This will help align the left and right halves while the glue is drying. Later, I'll cut this one long spar in half and they will become the flight spars.
