RCU Forums - View Single Post - Freewing Mig 29 EDF to Turbine Conversion
Old 11-14-2020 | 05:31 PM
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Equipment install
Everybody will do this different but here is what I did.
Access hole cut in front for airspeed module and then enlarged for battery. This allows the battery to move about 6 inches for CG adjustments
Hack saw blade used to make the deep cuts
Battery slides in on left side. AIrspeed module on right side. Air trap tank and pump on wood floor
The pump is mounted on top of the air trap tank. This is a 2 oz 3D printed tank by Keith that has the pump mounts on top. I use a Digitech CTU in all my jets and is mounted behind pump. A Castle 20 amp BEC supplies 5.7v power direct to the receiver and Freewing blue box. The ECU is next to the rear.
Velcro is applied to the blue box
The blue box is to the left of the header hank. The Jeti 12A receiver is where the stock blue box was mounted.
Here is the final layout. Note the vent line from the centerline tank comes up inside the fuse and wraps around the front of the Dubro tank and then back down and out the bottom of the jet. This is to prevent fuel siphon from the higher mounted header tank.
Turbine wires and fuel line goes through the right nacelle.
The fuel filter is loose mounted vertically for air bubble avoidance
The wires and fuel tube comes out the air inlet hole to the turbine
