RCU Forums - View Single Post - Freewing Mig 29 EDF to Turbine Conversion
Old 11-14-2020 | 06:07 PM
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Preflight testing
Fuel system tested using the pump test function to check the fuel feed from the centerline tank, to header tank, to air trap, to pump and back to jug. Everything checked good and the pump sucked it all out as planned
Pump running at PW 232. Header tank air was constant till the center line tank emptied
Turbine start and run worked great. No issues. I picked up the jet and held nose up vertical at full thrust and shook it hard. Not a burb and pump kept sucking the fuel from the centerline tank. A little less than 1 to 1 thrust but it really wanted to go!
No heat issues at all after start, run, shut off and cool down. Jet is ready to fly!
yeahbaby (11-14-2020)
