MJD is moving out pretty good..! My neighbor has a bicycle with a gas engine. IIRC, the gas engine conversion is a kit he installed.
I think the weight of the plane is within reason so far. I'm being as stingy as I know how with the cloth and the resin.
By the end of tomorrow I'll have a better idea about the weight because the plane will be much closer to being done.
TD .049 #2 I had laying around is slightly weaker than TD #1, but a P/L set just arrived from Cox International as well as a package full of the little plastic needle valve seals.
I've got enough junk laying around to put together a half decent TD...I think.
