RCU Forums - View Single Post - Freewing Mig 29 EDF to Turbine Conversion
Old 11-17-2020 | 04:59 PM
  #42
Viper1GJ's Avatar
Viper1GJ
My Feedback: (20)
Back in the shop after flying
I rechecked the weight and balance after flying. I found the empty weight with air trap full and unusable fuel in tanks was 11.13 lbs and CG was at 155mm or -15 mm from factory recommendation. I took 1 oz out of the nose and will test fly next at 11.04 lbs and CG at 160mm or -20mm from factory.
I am flying with about 3mm reflex in ailerons and flaps on both wings based on recommendations in other forums.
My trim setting flaps up. This trim setting is probably due to the reflex in the wing and the aft of factory CG.
Trim setting flaps down.
