High tech computer operations
I put this data into my high tech computer shown here
And the answer is 6 degrees. I guess I had around 2 degrees to start. Probably got to around 4 or 5 degrees with 2 washers at the field. Now about 6 degrees for next flights. We will see if this is too much and will go back to 2 washers if it is. Use this info at your own risk! Actually its probably close at 4-6 and nothing bad will happen.
Turbine can just below the nozzle shrouds.
