RCU Forums - View Single Post - Aviation Design Diamond Assembly!
Old 11-19-2020 | 07:55 AM
Canadian Man's Avatar
Canadian Man
Servo does not need to be tight against the cover. If it is, you may run into clearance issues. there is room in the servo mount to adjust a few MM's away from the mount which makes everything work.
Servo tight against cover
servo spaced out from cover.
