Originally Posted by
ravill
Where do you get receivers and are there really 28 channels?
Deeforce?
Yea Deeforce is the place. basically the radio comes with 16 stock channels and you can expand to get 28. So if you remove channel 16 you switch it to 4 more channels and now you have 19 Channels. Remove channel 15 and now you have 22 channels. The 11bpx that i'm using in this Diamond has 3 xbus outputs which can be 3 x bus channels or 6 xbus channels or 12 x but channels. The 16 bpx I used in the F18 Build is completely open xbus/pwm. A couple years ago I didn't understand it all but once I wrapped my head around how the Bus Systems work i love the simplicity of it.
Just look at our turbines now. They too are using a bus system so one cable from the data box (ECU or DRM) to the turbine and done.
Love this advancement in technology!
