RCU Forums - View Single Post - Electron retracts problem
Old 11-28-2020 | 07:11 AM
  #54
winter1's Avatar
winter1
Originally Posted by Dansy
You only have to reverse them (normally) if you reversed the retract from what how they were deliver, at least that’s my experience..
Hi Daniel,
yes, you need to do the mechanical adjustment first. I think the manufacturer supplies retractable gear set up to fit into the foam cutouts in the box.
The landing gear was delivered to me in a mechanical setup that could not be used for the T-1.
In the photo (above) is mechanically set reverse operation. That's fine for the T-1. Changing the settings is a matter of minutes. ***winter***
-This is why the polarity of the connectors must be reversed !-
