RCU Forums - View Single Post - New Powerbox Sensor Switch V3
Old 11-29-2020 | 08:36 AM
danielcaceres1991
Default Quick question
Hi, from what I understand when using the powerbox sensor the capacity of your batteries is added. For example if I plan on using 4000mah I can use 2 2000mah packs with the sensor. Is this correct, or do I need 2 4000mah packs?
