I use the Xicoy telemetry adaptor to display ECU info on my Jeti DS-24.
I would like to write a LUA script that displays the ECU status messages (User Off, Pre-Heat, Running, Cooling etc.).
The ECU Status message is not registered as an available output from the ECU adaptor.
As that info is available via the Jetibox, I presume that it is available somewhere in the low level telemetry adaptor data stream.
Does anyone know how to access the raw output from the ECU TM Adaptor?
And no, don't suggest I just buy a CTU.
I have checked with both Gaspar and Carsten Groen, the Jeti TM guru, both with no luck.
Paul
