Scx24 help
Hi not sure what happened. I answered your question. But it didn't post. You need to go to Kenon hobby it's the pn racing 70t 130 motor. 14$
from shapeways you'll need the v1 and v2 plates for transmission. They are made by gamey I think. The plates allow for the bigger motor. One is for speed allows a larger pinion. The v2 is for crawling. It faces the motor forward. About 15$, you'll also need a pinion as the stock one is to small for motor shaft. I have a bunch. So if you need one I'll put in envelope and send no charge. Hope this helps if you have any questions just ask. Good building
I'm unable to post pics as I'm a new member will try to finish the 10 post minimum today and post pictures of my build.
