Just one thing to be aware of. If you look at the top picture closely, you can see I used a piece of larger stick stock at the front of the frame where the side and bottom come together. This is to make sure the side panel is securely attached. That would otherwise be the weakest point of the sponson. Instead, it's actually one of the strongest
