I’m going to design a cradle which will hopefully help with assembly
Its much lighter than the composite fuse SkyMaster but the built up balsa fuse is a bit more fragile for handling and spreading the weight
I also plan on building a portable charging case dedicated to the plane, AC or built in LiFePO4 powered, just to keep the batteries topped up between flights
just not enough free time ...
