RCU Forums - View Single Post - Vortex F3A build thread
Old 12-30-2020 | 06:15 PM
  #245
eduaero
Originally Posted by Alex Voicu
Hi Eduaero,
I suppose you can replace the built-up wings and stabs with foam core construction. The shape would have to be modified a little, since you can't have a curved leading edge on the foam cores.
For the fuselage i don't think you can replace any of the balsa frames with depron, at least not without increasing the thickness significantly to have the same strength. This would require a complete redesign of the structure in the area of the depron parts due to the large number of interlocking parts.
thank you for taking the time to elaborate your response. You invested a lot of time to get this great design. I am not likely to change any bit of it so I will patiently try to find the adequate balsa you indicate
