Originally Posted by
jz37
... 2860rpm/volt - 1850rpm/volt Outrunner Motor with 70mm fan duct ...
Which of those two
velocity konstant Kv values? (in rpm/volt, Kv is a physical property, not a unit of measurement). Or is it just a typo?
Those two values would give two extremely different motors. Because both current and power
drawn are
proportional to Kv cubed. A factor of (2860/1850)³=3.6, i.e. 260% more current and power
drawn.
Note that
Kv says nothing about max.power and max.current capability. Like e.g. mass, Kv is not a rating, not a figure of merit.
Gelukkig Nieuw Jaar
en wees voorzichtig, Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
• E-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC •
