RCU Forums - View Single Post - CARF Ultra Flash Evo build thread +
Old 01-03-2021 | 11:09 AM
  #72
Dave Wilshere
A little more done today. I bonded the servo assembly to each cover plate last night, because the wing is curved and cover plate flat, when I do this I pack up the back edge 1mm on each cover plate and weigh down the servo frame, this creates a slight curve on the plate as the Hysol dries.
I’ve been playing with the brake cable run down the leg, so have not screwed the units in place yet. The nose door is tacked in place, the hinge area requires a long lead in to angle the hinge in an inverted V when the door is closed.
The JP gear works well on the nose, as it is it does not need a ramp on the door to stop the door catching the knuckle as the nose leg extends.
I’m going to pack the nose unit off the plate, so that may change things, we will see.
