RCU Forums - View Single Post - 1/10th scale Hydro Build
Old 01-05-2021 | 07:32 PM
  #56
Hydro Junkie's Avatar
Hydro Junkie
What did I do? I just told you what I have done on a few occasions to fix a shifted skin panel. That is the very reason I always oversize my parts by no less than 3mm on all sides. You can see that on the bottom picture on post 47. The deck extends around the sponson by roughly 3mm or so to make sure it didn't end up short. What I did do, however, is let the deck shift so that the deck didn't reach the edge aft of the sponson where it and the side panel didn't match. If you look closely at the deck edge by the rear of the boat, you can see a darker stripe that is the visible spruce glue strip inside the hull. Since this wasn't an area that would be hit by water or stressed, I used epoxy and microballoons, West Systems 410, to give the boat a sharp edge
