Originally Posted by
scale only 4 me
Duh, that makes waaayyyy too much sense.
I was too fast on the trigger there.
Thanks for correcting me.
init4fun
I think the OP may have mistakenly added the "kv" to the first set of numbers, perhaps that is what Ron was asking about ? ...
Yes, I interpreted it as two Kv numbers, I even calculated the star versus delta configuration numbers, instead of a size number and a Kv value.
All water under the bridge it seems, TS has not been active here since his OP.
Vriendelijke groeten
en wees voorzichtig, Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
• E-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC •
