RCU Forums - View Single Post - Proteus Bipe 2M need help with setting up flight modes
Old 01-23-2021 | 04:15 PM
orthobird
Default Proteus Bipe 2M need help with setting up flight modes
I am setting up a Proteus Bipe 2 meter pattern plane to compete with
I have set up the motor / esc / and the connections
Jeti DC24 transmitter
Jeti CB 220
ditex servos with telemetry, mini
Plettenberg Advance 30/10
D3 Motors F3A ESC - Governor
Jeti MUI150 EX
When setting up the transmitter, there is a lock switch to engage the motor on.
I also noted, that in device explorer, general setting, the output period was set to AUTO, and the motor, on plug into the the 10s system, only made 3 beeps and was missing the other 2 beeps.
SO when I changed the output period to the max, i think 30MS, then it made the 2 other beeps and the motor was then able to turn.
Now, I am at the stage that I would like to program flight modes.
On the Jeti DC 24 transmitter, i had Esprit install stick end switches. I am very comfortable using these, and have been for many years, as I am a pincher.
The left stick, the throttle side, i use a 2 position switch that on my IMAC airplanes is set up for low idle and high idle.
and on the elevator stick, there is a 3 position stick for:
1. IMAC precision rate, low elevator, ailerons are tame, rudder set up to hold knife edge
2. roller rate= ailerons are brought down to 8% of dual rates
3. hammer head = max rudder deflection
Being that this pattern airplane is an electrifried, what do most guys do for the flight modes?
sincerely
Cam
