Under other model options you can select a switch that will disable the motor. Nice little safety feature that I use on all of my EP models.
I run three flight modes, normal flight, spin and a high rate rudder for stalls. I also use logic switches on stick positions to activate snaps.
Also, the CB 200 is kinda overkill for an f3a model. I would save that for a gas model and just use an R9 with a couple of 500mAh batteries.
