Hi Malcolm,
Thanks again for your recommendations. I think that would add some stiffness to the rod end joints and it is certainly something I can do. Getting the rod ends stiff and solid will stop small shifts in position and make the slider rod more likely to stay in position. Great Idea. I will have to order some and get it in the joints there. How long do you have to let it cure before moving the joint?
Gary
