RCU Forums - View Single Post - Painted wing, stabs and advanced graphics
Old 02-04-2021 | 07:34 AM
  #381
Bubblehead575
Pat
I have used your methods to do an Agenda and it came out great. However it didn't last long due to a dumb mistake on my part. I am attempting to use it again on a scratch built plane I have. It has a 60 inch built up wing and fully sheeted. Due to some soft balsa skins on the bottom of the wing I decided to use the carbon fiber tissue you and Matt discussed here, for added strength. I put 2 Coats of Lacquer on all surfaces first, and then sanded with 220. However when I put the carbon tissue down with Poly, using the same method as with silkspan, the fiber started separating and moving so I didn't get the poly squeesed out as well as I would have liked. And the panels buckeled.
Not sure if the buckle is because of the excess Poly or bad glue job on the sheeting, or perhaps I should have added a third coat of Lacquer.. Any insite from you would be greatly appricated before I do the top and mess it up too.
Thanks Bill
