Another issue was using full size servos on the ailerons rather than the minis which were called for. These are digital and should be very accurate as well as more powerful. They fit in without significant modification to the wing. I did use minis for flaps, full size for elevator and rudder. All the provided linkages on the model seemed okay so that is what I used. There is no slop anywhere so it should be all good.
