RE: Webra .50 Alternative
you can, you can beat it to death with a West, it's a Webra with diffrent porting and cooling fins
T1 is low end grunt, tho it doesn't rev like you would expect a normal engine to, once it gets to about 14k its given all the power it has. use the right prop
the V1 has it's power band at 20-21K
the T1 on a 12.25x3.75, 13x4 or 13x4W is perfect. 4 lbs is about where the Hype 3D is and it's the engine made for it.
