I took the right wing off again and removed the right main gear. It appeared that the slider bar was hanging up on one side as did the nose gear. It looks like the weight of the wheel and strut is pressing more on one side of the up lock cam than the other. There are some marks on the side that hangs that are not on the other side. I may try to sand and polish that surface a little like I did to the nose gear and see if I can get that cylinder to pull together with the other side.
The cone point set screws show promise with the initial sets. I will have to see when I finally get the gear working.
Short week in the shop. Packing the camper and going to the Flying Tigers Chili Cook Off and Fly In on Thursday. The saga continues...
Gary
