Good day Sir.
Thank you for your reply regarding the KMP Edge.
I wanted to find out what the total waight of the plane needs to be. I notedt that after mounting the Motor she is still VERY tail heavy. I need to add about 400g of lead to balance her out. Total dry is 7.5Kg (16.5 Pound) With fuel she will come in at 8Kg (17.6 Pound)
Secondly I had to alter the firewall a bit to fit the motor. I used the same box angle ect when I cut it. Can I use the Cowl as a guide as to the exact location where the motor must be mounted. (Was actully looking for a type of template).
Lastly. How does this bird fly? Were you happy with her? She is my first 50cc coming from 30cc and 90Size planes. So im a bit intimidated by her size ;-)
Regards
Pierre C Mentz
