RCU Forums - View Single Post - Help with binding
Old 03-16-2021 | 03:31 AM
suicide2
Originally Posted by GREG DOE
If I read your post correctly the right stick is operating your elevator, and not your left stick? That would be Mode2
Do you want the elevator on the left stick, which would be Mode1? I not certain that that transmitter can be changed
to Mode1. If it can, you are going to have to go into the programming. You will also have to loosen the spring on the
right stick, and engage the spring on the left stick. A manual, and someone who has done it before would be a big
help.
Greg,
no nothing works after I binded the radio to the plane except for the elevator. I don’t get ailerons, rudder or even the prop to spin. The only thing I get is the elevator and it only goes up not down and it’s on the right stick. On my other radio when I bind the plane everything works exactly as it should, I even get the safe feature. I reached out to the seller and see if he changed modes or anything. Hopefully I’ll have some kind of answer this afternoon. If anything I’ll send it back and get a refund.
