RCU Forums - View Single Post - Having problems with my dle 20 ignition.
Old 03-21-2021 | 01:48 PM
Truckracer
My Feedback: (19)
Click? What do you mean by click? If you are talking about the ignition firing the plug when you turn the prop, the newer ignitions will only fire the plug when you turn the prop at cranking speeds or above. Simply turning the prop won’t fire the plug. If you are talking about another problem then a better description of the problem is needed.
