Fabricating tank plumbing. PIcs are pretty much self explaining
Marking loation of feed tube. Pickup is in center rear of tank. Output goes vent on left saddle tank through the round hole.
Marked back edge of tank
Marked top view
Scrap 1/16" G10 used for tank fixtures. 15 x 15mm squares used for pick up tube stand off
Tube has to clear 5mm rib on back of tank
Two squares of G10 glued together with medium CA
The plot!
Hole drilled for tube
All gluing surfaces are scuff sanded inside and outside the tank
Scuff sanding back wall for standoff
Scuff sanding inside of tank. Outside done too
Top hole location marked away from back edge
Hole set for 5mm off the inside back wall
Drilled
Tubing dry fit and marked for cut.
