RCU Forums - View Single Post - Hing Gap on Elevator ????????????
Old 11-10-2003 | 08:04 PM
rctrax
Default RE: Hing Gap on Elevator ????????????
I use clear monokote to seal the gaps. just cut a 3/4" or 1" wide stripe and iron it on with the control surface completly deflected in the opposit direction and when you return the surfsce to neutral run the iron down the seal and it will push the seal down into the hingeline. It will be virtualy invoisable. Doing it from the bottom works best. you will forget it's there.rctrax
