RCU Forums - View Single Post - Runway Question
Thread: Runway Question
Old 05-07-2002 | 02:25 PM
TopShelf
Default Runway Question
Since no one else replied, I'll give you my .02. It all depends on how rough the surface is and what kind of plane you are flying.
Assuming the surface is pretty well packed and and not too irregular, you should be ok. It's not much different from an "off field" runway many have been forced to make. Another alternative would be a smooth patch of packed dirt.
If you are flying a plane that has a slow landing speed, I would imagine you should be ok. Put some big tires on it, find the smoothest spot and give it a go. If you can't taxi fast enough to take off, then you have a problem.
