I have the EVSD-5U-PRO valve in my turbine jet and it had a Futaba receiver and radio system. The valve worked perfectly last summer with Futabu. It was changed to a Spektrum system since that is what I use. Since then, the gear and doors work perfectly but the brake function does not. The brakes keeps cycling no matter what is changed and we have reviewed the manual and settings. I have the AR20310T DSMX 20-Channel PowerSafe receiver with 6.6V LiFe receiver batteries.
Is there some special setting with a Spektrum radio system that is needed to make the brake valve work properly?
Thanks.
