New servos tweeking
Put a small foam plane together, used new light cheap 9g. I plugged everything in and it seems that the ailerons lag a split second.
And the more I test it the worse it gets, sometimes servos twitch with no input on stick.
I changed out the esc a few times along with half dozen receivers that were known to work. More of the same.
I've been using Spektrum system. I even broke out my Taranis I bought a few year back sitting on a shelf,
same result but even worse. Not just servos twitching and turning but the damn throttle was activating also.
I glued the servos in like I didn't want them to come loose. I don't know what else to do but change the dreaded servos.
Appreciate any help. Thanks
