Originally Posted by
speedracerntrixie
................. Can you imagine what the noise floor is during an NBA or NHL event? Still never an issue.
Unlike you I don't have to imagine. I know what the RF noise floor would be. Assuming all the equipment is properly tuned and aligned, the RF noise floor will be pretty much where it always is. Typically around negative 80 to negative 90 db. All the equipment in use should appear as individual signals rising above the noise floor.
Unless of course you don't agree?
Retract servos are suitable to be used only for retracts! Not boat rudders, sail control, flaps or anything else that might require a little thought.
2.4 GHz is immune to RFI.
So sayeth Speedracer the omnipotent.
To the Bit Bucket with you!
