RCU Forums - View Single Post - UP2 Valve problem
Old 05-04-2021 | 05:39 PM
Redtailpilot
Default UP2 and Tricycle Gear
Sorry for the rookie question, but I see where the UP2 Valve is set up for two struts (main gear). My question is how do you connect the nose gear retract to the system? Do you use a T-fitting to run an up and down line, if so, how and where do you run a T-fitting into one of the set of strut valves. Hope I am making sense guys. Thanks for your help. Chic
