Originally Posted by
eric_rico
I have a brand new P400-PRO series and have it mounted on a bench with load cell sensor attached in front of the engine. At max rpm 97,000, my engine only generate 27kgf on the load cell sensor. By the way the load cell sensor I use is iLoad TR series from Loadstarsensors and the environment in my workshop is <100m ASL and >50% RH. Can anyone tell why my JetCat is not producing enough thrust?
Hi dear. Did you get the solution of your problem. I am also having same problem. The thrust is less and Exhaust temperature is also less
