I use a barbed fitting to connect the festo type fuel line to the tygon fuel line. Then the festo type fuel line goes into a festo fitting. Depending on the size of your tygon fuel line, you may need an adapter (e.g. 6mm to 4mm). Tygon tubing will not work well when placed directly into a festo fitting.
