As noted, there really isn't an everything combination kit to build, with all components and radio.
I'll throw out one suggestion - look at a Sig LT-40 kit. As supplied, it is for glow engines. BUT, SIG sells an Almost-Ready-To-Fly version that is capable of glow OR electric The modifications are minor. Download the instructions for each, and note how little additional needs to be customized on the kit, using the information from the ARF instructions for the electric version. You will have a complete list of the additional components needed to convert the kit to electric AND an excellent "how-to" for installing them. The kit does not have a cowl, so would need a small bit of change to make sure the motor is mounted to have the prop clear the sides like the glow version does. At worst, some added glued in plywood squares to "shim" the motor forward, with four longer bolts back through the firewall to hold it all firmly together. That's all. Then you have the experience of both building a very well documented kit AND customizing it a little to suit your preferences.
