Originally Posted by
Vilante
Is there any reason you couldn't use a single sheet for the decking?
Depends on the shape of the deck more than anything. If you look at this picture, you can see that the deck is one piece on each side. With my scale Pak build, I will need to use a third piece for the deck between the sponsons where it drops below the sponson inside tops due to the deck's shape. It's got a compound curve that can't be done using just one piece per side
