RCU Forums - View Single Post - 1/10th scale Hydro Build
Old 07-02-2021 | 04:50 AM
  #116
Hydro Junkie's Avatar
Hydro Junkie
That's weird, considering I took it from my build thread. Let me try again:
https://www.rcuniverse.com/forum/att...3&d=1375582323
Let's see if that works.
Now, as for your colored deck layout, let me go over it as this isn't a big issue, regardless of how it looks:
RED, one piece each. Make sure you cut them both oversized since the part that drops down in front between the sponsons will be longer than shown. Same thing for all of the deck edges, they will require more material than shown due to the arcing shape of the deck
BLUE, hard mount it to the hull, just like the red. Make sure to extend this area back to where the purple and yellow meet up and become flush. This is important for sealing the hull with tape when you are running it later, that is unless you install an internal water resistant cover and tape it up instead.
PURPLE, YELLOW AND GREEN, make this all one piece. The purple could be hard mounted to the hull if you want, it's really your choice. As far as the yellow and green, you will want to make that all one piece and permanently attach the cockpit, engine cover and exhaust pipe to it. What you need to remember is that the tighter you make things, the harder it will be to work on later. If you look at the picture of my scale Elam Plus in post 5, you can see the cowl covers everything except the very rear of the boat. Unlike your boat, mine has a metal cover that matches the heat shield on the full sized boat. This was not the case on your boat since there was less decking between the exhaust and the rear of the boat so it wasn't needed.
