RCU Forums - View Single Post - Is there any point...
Old 11-11-2003 | 10:36 AM
phread59
Default RE: Is there any point...
Hi Crashem:
I say absolutely YES! I find the tighter the control linkages the better the plane will fly. Use the best quality horns and clevises that you can afford. You will be pleased with the results. I will add my favorite trick. When using plastic tube in tube nyrods I take 2-56 allthread. And at the ends of the rod I use a chordless drill with a keyless chuck to screw a long length of all thread into the nyrod. Make sure the allthread will go all the way into the fusalage or in past the outer casing on the inside. Just make sure there is no binding and you are set. You will be amazed at the difference this makes. As I said go for it.
Mark Shuman
